I'm having a strange problem. I have a XamDataGrid (2011.2) that has a field with TextWrapping enabled. In some cases, the text seems to wrap prematurely independent of the width of the cell.
For instance - "Kit" shows up as "Ki" when not in edit mode, and "Kit" in edit mode. However, if I enter "Kite" or "kit" or "Kit XXX" or " the entire text shows up. If I shrink the column so that it only displays one or two characters per line, the entire word shows up, just on different lines.This seems to happen to
When I turn off text-wrapping, this problem goes away.
I've attached a sample project that demonstrates this - all of the words listed in the project are causing problems in my real project, but strangely, the only one causing a problem in the sample is "Bit".
How do I fix this (without turning off text wrapping)?
Thank you for your feedback. I am glad that you resolved your issue and I believe that other community members may benefit from this as well. Also I can say that this behavior occurs by design and in most cases it looks nice, but it cannot cover all the Fonts, FontWeights and FontSizes.
Thanks again.
Thanks! That seems to have fixed the problem. I was wondering if you could tell me why this is necessary though? Just a bug?
Thank you for your post. I have been looking into it and the sample project you have attached and I suggest you add the following Setter to your XamTextEditor Style in the XamDataGrid’s FieldLayoutInitialized event:
cellEditorStyle.Setters.Add(new Setter(XamTextEditor.PaddingProperty, new Thickness(0)));
Please let me know if this helps you or you need further assistance on this matter.
