I have used the xamdatagrid and created some trigger event with the help of interaction Triggers.
I have written its method in view model but Its not working data binding is working proerly for grid but theres some issues in binding trigger. Please find below code snippes .
I have aslo attached the code sample which might be useful to undestand my issues.
<i:Interaction.Triggers> <i:EventTrigger EventName="CellUpdated" SourceName="xamDataGrid1"> <ei:CallMethodAction MethodName="{Binding Path= xamDataGridCellUpdated}" TargetObject="{Binding ElementName=TestViewModel}"/> </i:EventTrigger> <i:EventTrigger EventName="CellActivating" SourceName="xamDataGrid1"> <ei:CallMethodAction MethodName="{Binding Path= xamDataGridCellActivating}" TargetObject="{Binding ElementName=TestViewModel}"/> </i:EventTrigger>
</i:Interaction.Triggers>
Looking forward for your kind relay.
Can Any one help me on this?
Still I am not able to resolve it.
Looking forward for your plasure reply.
Thank you for your post. I have been looking into it and the sample project you have attached and I suggest you use the following code for the Interaction instead of yours:
<i:Interaction.Triggers> <i:EventTrigger EventName="CellUpdated" SourceName="xamDataGrid1"> <ei:CallMethodAction MethodName="xamDataGridCellUpdated" TargetObject="{StaticResource myVM}"/> </i:EventTrigger> <i:EventTrigger EventName="CellActivating" SourceName="xamDataGrid1" > <ei:CallMethodAction MethodName="xamDataGridCellActivating" TargetObject="{StaticResource myVM}"/> </i:EventTrigger> </i:Interaction.Triggers>
Also you should add this to the Resources of your XamDataGrid:
<igDP:XamDataGrid.Resources> <local:TestViewModel x:Key="myVM"/> </igDP:XamDataGrid.Resources>
And this namespace, too:
xmlns:local="clr-namespace:SpreadsheetFramework.Client.ViewModel"
Please let me know if this helps you or you need further assistance on this matter.
Hi Stefan,
Thank you very much for prompt reply.
I have tried with this statice resouces but in that case my Viewmodel Constructor is getting called twice.
In our scenario , we are actully adding differenct usercontrol(view) based on Ribbon control button click event into content place holder and if you check the MainwindowResource file , there we have provide the databinding between the view and viewmodel. If I remove that binding and kept only your statice binding it will not getting display.
So, thats issues i was facing right now. Kindly suggest solution for this.
Thx,
Jay
Hello Jay,
I have been looking into your requirement and in that case I suggest you use the following code:
<igDP:XamDataGrid Grid.Row="1" AutoFit="False" MaxHeight ="660" Width="545" DataSource="{Binding Path=EmpList,Mode=TwoWay}" DataContext="{Binding UpdateSourceTrigger=PropertyChanged}" HorizontalAlignment="Stretch" x:Name="xamDataGrid1" VerticalAlignment="Stretch" BorderBrush="Black" Theme="RoyaleStrong" BorderThickness="1" Margin="10,10,10,10" Height="260" > <igDP:XamDataGrid.FieldLayoutSettings> <igDP:FieldLayoutSettings HighlightAlternateRecords="True" AutoGenerateFields="True" AllowAddNew="False"></igDP:FieldLayoutSettings> </igDP:XamDataGrid.FieldLayoutSettings> <igDP:XamDataGrid.FieldSettings > <igDP:FieldSettings AllowEdit="True" AllowGroupBy="False" AllowRecordFiltering="True"></igDP:FieldSettings> </igDP:XamDataGrid.FieldSettings> <i:Interaction.Triggers> <i:EventTrigger EventName="CellUpdated" SourceName="xamDataGrid1"> <ei:CallMethodAction MethodName="xamDataGridCellUpdated" TargetObject="{Binding}"/> </i:EventTrigger> <i:EventTrigger EventName="CellActivating" SourceName="xamDataGrid1"> <ei:CallMethodAction MethodName="xamDataGridCellActivating" TargetObject="{Binding}"/> </i:EventTrigger> </i:Interaction.Triggers> </igDP:XamDataGrid>
Basically I changed the DataContext of the XamDataGrid and its DataSource binding, so that I can use the DataContext in the EventTriggers. Pease let me know if this helps you or you need further assistance on this matter.
It works !!!!!! :)
Many Many Thanks !!! You really help me lot to resolve this !!! you are really amazing !!!
Thx ,
JaY
Thanks again.
