I have my datagrid set up with checkboxes as the RowSelector as per the Feature Browser example. I'm looking for a way to find out if the RowSelector is part of an alternate row so I can have it styled with the same background color as my alternate row style for DataRecordCellArea. For example, I need to do something like this...
<Style TargetType="{x:Type igDP:RecordSelector}" BasedOn="{x:Null}">
<Setter Property="BorderBrush" Value="#DFDFDF"/>
<Setter Property="BorderThickness" Value="0,0,0,1"/>
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type igDP:RecordSelector}">
<Grid>
<Border BorderThickness="{TemplateBinding BorderThickness}" BorderBrush="{TemplateBinding BorderBrush}" VerticalAlignment="Bottom" HorizontalAlignment="Stretch"/>
<CheckBox HorizontalAlignment="Center" VerticalAlignment="Center" IsChecked="{Binding Path=DataItem.IsSelected, Mode=TwoWay}"/>
</Grid>
<ControlTemplate.Triggers>
<DataTrigger Binding="{Binding Path=IsAlternate, RelativeSource={RelativeSource Mode=FindAncestor, AncestorType={ x:Type igDP:DataRecordCellArea}} }" Value="True">
<Setter Property="Background" Value="Red" />
</DataTrigger>
</ControlTemplate.Triggers>
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
Obviously this doesn't work because the RowSelector isn't a child of the DataRecordCellArea. Any help would be appreciated, thanks.
Thanks again.
Worked great, thanks! I didn't realize that DataRecordPresenter had an IsAlternate property (should have looked at it's base class RecordPresenter).
Thank you for your post. I have been looking into it and I suggest you use the following Style instead of yours:
<Style TargetType="{x:Type igDP:RecordSelector}" BasedOn="{x:Null}"> <Setter Property="BorderBrush" Value="#DFDFDF"/> <Setter Property="BorderThickness" Value="0,0,0,1"/> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="{x:Type igDP:RecordSelector}"> <Grid x:Name="grid" > <Border BorderThickness="{TemplateBinding BorderThickness}" BorderBrush="{TemplateBinding BorderBrush}" VerticalAlignment="Bottom" HorizontalAlignment="Stretch"/> <CheckBox HorizontalAlignment="Center" VerticalAlignment="Center" IsChecked="{Binding Path=DataItem.IsSelected, Mode=TwoWay}"/> </Grid> <ControlTemplate.Triggers> <DataTrigger Binding="{Binding Path=IsAlternate, RelativeSource={RelativeSource AncestorType={ x:Type igDP:DataRecordPresenter}} }" Value="True"> <Setter TargetName="grid" Property="Background" Value="Red" /> </DataTrigger> </ControlTemplate.Triggers> </ControlTemplate> </Setter.Value> </Setter> </Style>
Please let me know if this helps you or you need further assistance on this matter.
