Hi there
I have a request from customer. Basically he is able to resize the columns as he wished and also - change their position. All works great, however there is a small issue when resizing.
If I grab the right edge of the column and move it a little bit to the right (which means: I want to resize), what is happening is that also the left edge of the column is resized - it was moved a little bit to the left.
The expected behaviour would be that If i resize right edge, the left edge stays exactly where it was before.
I didn't find any property to control that.
Thx for any feedback.
Hello Lukasz,
Thanks again.
Thx for feedback.
Yesterday I've played a little bit with it, and I solved the problem.
The behaviour was that it occured when AutoFit mode was set to Auto. When I set AutoFit to False, then the columns remain in the original position when the edge is moved.
Thx again!
Thank you for your post. I have been looking into it, but I wasn’t able to reproduce your behavior, so if this is still an issue for you, could you please send me an isolated sample project, where this is reproduced, so I can investigate it further for you.
