I'm sure this is a simple question, but after several hours of searching, I've been unable to find any examples. I'm using XamDataChart with a simple column series in a fairly simple "drill-down" type of application. When the user double-clicks on one of the category values, I need a way to determine the value of the category so I can use it as a filter for other activities on the window.
I'm converting this form over from one which was previously using the XamChart. In that form we used things like DataChart.HitTest to get a HitTestArgs object and then used the SelectedObject method to get the DataPoint which received the click. There doesn't appear to be anything similar in the XamDataChart.
Any help would be greatly appreciated.
Steve
Hello petrinat ,
I believe that currently your best option in order to achieve this is the approach discussed in the following forum thread:
http://community.infragistics.com/forums/p/50226/264216.aspx
By handling the MouseDoubleClick you can calculate the unscaledX value and depending on your axis type it will return a double value that indicates the position of the mouse click as I already suggested in my previous post- you can achive this by getting the unscaled value and find the coresponding point in your data source collection.
If you need any further assistance on this, please do not hesitate to ask.
Hi Elena,
I am using XamDataChart and I have category x axis. How do I get the actual x value for the data point in the series mouse down event handler?
Thanks in advance
Hello Steve,
If you still need any assistance on the matter do not hesitate to ask
Just to be clear, would you please specify the type of axis that you use for your series- category, numeric, olap, ets .
I have been researching this for other possible approaches to achieve this and currently with exposed functionality you can get the clicked series by handling the XamDataChart’s SeriesMouseLeftButtonDown event and use e.Series . Still I will continue investigating the described issue and I am going to contact our developers about this. I will update you as soon as I have more information for you.
Thank you for your patience.
