350
Switching Datasources
on application startup a xamDataGrid is bound to static resource:
<Grid.Resources>
    <XmlDataProvider x:Key="Data" XPath="/Ntn">
        <x:XData>
            <Ntn xmlns="">
                <Note GridHeaderSA="SA" GridHeaderKA="KA" GridHeaderEx="Ex" GridHeaderM="M" />
            </Ntn>
        </x:XData>
    </XmlDataProvider>
</Grid.Resources>
This xmlDataProvider is bound as datasource:
<igDP:XamDataGrid DataSource="{Binding Source={StaticResource Data},XPath=Ntn}" />
At runtime data is gathered and loaded into an ObservableCollection and this collection is bound to the xamDataGrid:
Me.gridNtn.DataSource = myDataCollection
Now would like to create the following behaviour:
If data is loaded correctly, i would like to view this in the grid. If loading fails, the grid should "fallback" to the static resource. But how to do this in Code?
In short terms: is it possible to bind a xamDataGrid to static resource in code?
thanks in advance
Stephan
