1564
How to handle the "DataPresenterCommands.StartEditMode" event in a custom DataRecordPresenter ?
In my xamDataPresenter I have create a custom "DataRecordPresenter" where I have something like this :
<Style TargetType="{x:Type igDP:DataRecordPresenter}">
Setter Property="HeaderAreaBackground" Value="{x:Null}"/>
Setter Property="Template"> .... </Setter
  <Setter Property="TemplateCardView">
Setter.Value>
ControlTemplate TargetType="{x:Type igDP:DataRecordPresenter}">
StackPanel>
          <vov:VideoThumbnail IsSelected="{Binding IsSelected}" MediaData="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=DataRecord.DataItem}"/>
<ContentPresenter
x:Name="PART_RecordContentSite"
Visibility="Collapsed"
Content="{TemplateBinding DataContext}"
ContentTemplate="{TemplateBinding RecordContentAreaTemplate}"/>
        </StackPanel>
ControlTemplate>
Setter.Value>
Setter>
Style>
Now in my code I call this code to start the edition :         xdgMedias.ExecuteCommand(DataPresenterCommands.StartEditMode);
But I would like to handle the corresponding "event" in my "vov:VideoThumbnail" control.
Do you know how I can do this ?
  • 9694
    There are a few ways you can do this. As you probably have discovered, you cannot simply access the VideoThumbnail since it is declared in a template.
    One way is to use the VisualTreeHelper to look for the ViewoThumbnail during runtime. The object is embedded in the Field and can be accessed through the Field hierarchy.
    A simpler way would be to provide an event for when the VideoThumbnail is initialized. In the event handler you can store a reference to the object for later access.
    The great thing about WPF is there are probably several other solutions.
