255
Eliminate margin on cells when background color is applied
Hi
I have a xamdatagrid and the following style which I apply to certain field.Settings.EditorStyle in code:
<Style x:Key="readOnlyStyle" TargetType="{x:Type igEditors:XamTextEditor}">
 <Setter Property="Background" Value="LightGray"/>
 <Setter Property="Margin" Value="0"/>
 <Setter Property="BorderThickness" Value="0"/>
</Style>
I am trying to eliminate the border highlighted on the attached sreenshot but cannot seem to find a way of doing so. I do not explicitly set border thickness anywhere else on the grid either.
  • 138253
    Verified Answer
    Thank you for your post. I have been looking into your requirement and I created a sample project for you with the functionality you want. Basically I cretad a Style for the CellValuePresenter and set its Background, Margin and BorderThickness Properties the same way as in your Editor and applied it to the same Field in order to hide the lines you have. Please let me know if this helps you or you need further clarifications on this matter.
    XamDataGridMargin.zip
