Hello!
In my application, I'm using xamGrid and I need the Add New Item row to appear when a button is clicked and be instantly editable. I didn't find a proper way to activate the row editor on the Add New Item row, so I used to following hack:
xamGrid.AddNewRowSettings.AllowAddNewRow = AddNewRowLocation.Top; xamGrid.UpdateLayout(); var newRowCheckboxCell = Infragistics.Windows.Utilities.GetDescendantFromType( xamGrid, typeof(AddNewRowCellControl), true);var cellToEdit = (newRowCheckboxCell as AddNewRowCellControl) .Cell.Row.Cells[1];xamGrid.EnterEditMode(cellToEdit);
However, when I finish editing the row (either pressing Enter or clicking outside the row), the row is not added and the RowAdded event does not fire. I must enter and exit the edit mode manually once more time for the row to be added. Why is this happening and how can this be worked around?
We seem to have come up with a solution on our own:
The problem arises when xamGrid.EditingSettings has AllowEditing property set to Row, but I'm using the EnterEditMode override with cell only. If I use another override and pass both cell and row, the event fires correctly.
HI AntonK,
I replicated your issue and I am working on a resolution.
Sincerely,Matt Developer Support Engineer
