645
Ribbon upgrade
I recently updated my application from infragistics v10.3 to v11.1.   When i did so my Main application ribbon bar now shows empty when it is first loaded. I have to hit on the second tab and then i see all the buttons.  I hit back to the home tab and everything is there.
When debugging the application my home tab - [first tab] is the selected tab.  but I did notice that the Active Data Item = null right before the screen opens.
How can i fix this?  I did not have this problem on the old version.  Also with the new upgrade some machines are reporting seeing black areas on the screen when first loaded. [like the ribbon tab is all back and my outlook bar but if you resize then everything shows.
