795
Barcode reader returning empty value for tiff file
Reading Tiff file:
I am trying to read barcode of a multipage tiff file using the below code. But it is returning empty string after reading the page. I have attached the tiff file with this post. Please advise  me what is wrong in this code and why it is not able to read the barcodes available in the page.
Reading Pdf file:
Apart from the tiff, I want to read barcodes from pdf fiiles. Please what are the APIs which support reading barcodes from PDF files in infragistics? If possible pls provide some code samples to read barcodes from pdf files.
The below code reads bar code from tiff file.
using System;
using
System.Collections.Generic;
using
System.Linq;
using
System.Text;
using
System.IO;
using
System.Windows.Media.Imaging;
//using System.Drawing;
using
System.Windows;
using
System.Windows.Controls;
//using System.Windows.Media;
using
Infragistics.Controls.Barcodes;
namespace
ConsoleApplication1
class Program
static void Main(string[] args)
Stream imageStreamSource = new FileStream(@"C:\Data\Srirangam\test.tif", FileMode.Open, FileAccess.Read, FileShare.Read);
TiffBitmapDecoder decoder = new TiffBitmapDecoder(imageStreamSource, BitmapCreateOptions.PreservePixelFormat, BitmapCacheOption.Default);
BitmapSource bitmapSource = decoder.Frames[1];
BarcodeReader barReader = new BarcodeReader();
barReader.BarcodeOrientation =
SymbolOrientation.Unspecified;
barReader.MaxNumberOfSymbolsToRead = 5;
barReader.DecodeComplete +=
new EventHandler<ReaderDecodeArgs>(barReader_DecodeComplete);
barReader.Decode(bitmapSource,
Symbology.All);
static void barReader_DecodeComplete(object sender, ReaderDecodeArgs e)
String barValue = e.Value;
Console.WriteLine(barValue);
using
using
System.Linq;
using
System.Text;
using
System.IO;
using
using
System.Windows;
using
using
namespace
ConsoleApplication1
class Program
Symbology.All);
using
using
System.Linq;
using
System.Text;
using
System.IO;
using
using
System.Windows;
using
using
namespace
ConsoleApplication1
class Program
Symbology.All);
test.zip
