795
Reading barcode from tiff file returns empty string
Reading from Tiff file
I am trying to read barcode from multipage file, but it is returning empty string after reading the tiff file. I have attached both code I am using and till file with this post. Please advise me why it is not able to read the barcodes from tiff file.
Reading from Pdf file
Apart form tiff, I want to read barcodes from pdf files also. Please advise me what APIs are provided by infragistics to read barcodes from pdf file. Please throw some code samples for reading barcode from pdf files.
The below code is to read barcode from tiff file.
using
System;
using
System.Collections.Generic;
using
System.Linq;
using
System.Text;
using
System.IO;
using
System.Windows.Media.Imaging;
//using System.Drawing;
using
System.Windows;
using
System.Windows.Controls;
//using System.Windows.Media;
using
Infragistics.Controls.Barcodes;
namespace
ConsoleApplication1
class
Program
static void Main(string
[] args)
Stream imageStreamSource = new FileStream(@"C:\Data\Srirangam\test.tif", FileMode.Open, FileAccess.Read, FileShare
.Read);
TiffBitmapDecoder decoder = new TiffBitmapDecoder(imageStreamSource, BitmapCreateOptions.PreservePixelFormat, BitmapCacheOption
.Default);
BitmapSource
bitmapSource = decoder.Frames[1];
BarcodeReader barReader = new BarcodeReader
barReader.BarcodeOrientation =
SymbolOrientation
.Unspecified;
barReader.MaxNumberOfSymbolsToRead = 5;
barReader.DecodeComplete +=
new EventHandler<ReaderDecodeArgs
>(barReader_DecodeComplete);
barReader.Decode(bitmapSource,
Symbology
.All);
static void barReader_DecodeComplete(object sender, ReaderDecodeArgs
e)
String
barValue = e.Value;
Console
.WriteLine(barValue);
Regards
Uthay
test.zip
  • 138253
    Hello Uthay,
    Thank you for your post. I have been looking into it and I can say that the Barcode Reader can read .JPEG and .PNG files. Here you can read more about the Reader:
    http://help.infragistics.com/doc/WPF/2013.2/CLR4.0/?page=IG_Barcode_Reader.html
    and in the Feature Browser under Infragistics Barcode Reader / Key Features / Reader Settings section you can see how to decode pictures.
