I only want to show red dot for each datapoint in the line chart, not value.
Any help is greatly appreciated.
--xaml file---
<Window x:Class="XamChartMarkerVisibility.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" Title="MainWindow" Height="350" Width="525" xmlns:igCA="http://infragistics.com/Chart"> <Grid> <Grid.Resources> <Style x:Key="NoLabelMarker" TargetType="{x:Type igCA:Marker}"> <Setter Property="Fill" Value="Black"/> <Setter Property="Stroke" Value="Black"/> <Setter Property="MarkerSize" Value=".5"/> <Setter Property="Foreground" Value="Transparent"/> </Style> <DataTemplate x:Key="dt"> <Ellipse Width="10" Height="10" Fill="Red" Loaded="MLoad"/> </DataTemplate> </Grid.Resources> <igCA:XamChart Name="ColumnChart2D" Grid.Row="1" > <igCA:XamChart.Legend> <igCA:Legend Visible="False"/> </igCA:XamChart.Legend>
<!-- Data points --> <igCA:XamChart.Series>
<igCA:Series Label="Goal" x:Name="goalSeries1" ChartType="line" StrokeThickness="0" Fill="#FFD70005"> <igCA:Series.DataPoints> <igCA:DataPoint Value="0.0" Label="A1" /> <igCA:DataPoint Value="0.5" Label="A2"/> <igCA:DataPoint Value="0.8" Label="A3"/> <igCA:DataPoint Value="0.7" Label="A4"/> <igCA:DataPoint Value="0.9" Label="A5"/> </igCA:Series.DataPoints> <igCA:Series.Marker> <igCA:Marker UseDataTemplate="True" DataTemplate="{StaticResource dt}"/> </igCA:Series.Marker> <igCA:Series.Animation> <igCA:Animation BeginTime="00:00:0.75" Duration="00:00:02"/> </igCA:Series.Animation> </igCA:Series>
</igCA:XamChart.Series> </igCA:XamChart> </Grid></Window>
--code behind file:--
using System.Windows;using System.Windows.Controls;using System.Windows.Shapes;
namespace XamChartMarkerVisibility{ /// <summary> /// Interaction logic for MainWindow.xaml /// </summary> public partial class MainWindow : Window { public MainWindow() { InitializeComponent(); }
void MLoad(object sender, RoutedEventArgs e) { var parent = ((sender as Ellipse).TemplatedParent as ContentPresenter).Parent; if ((sender as Ellipse).TranslatePoint(new Point(0,0),parent as UIElement).Y == ((parent as FrameworkElement).ActualHeight )) { (sender as Ellipse).Opacity = 0; } } }}
it's been resolved. Thanks!
Hello Lily,
I found this post duplicate to the following one:
http://forums.infragistics.com/forums/t/65098.aspx
Which is already answered.
