I have a grid with more records than can be displayed. The first element in the grid is XamCheckEditor. When I scroll away from me, it checks the current record, when I scroll toward me it unchecks the current record. I don't want the scroll wheel changing any data. Is their a property that I'm missing?
Hello air1kfd,
I am very glad that you have solved your issue. I hope that all this can be heplful for other visitors of our community.
Somehow I missed your fix. I downloaded this yesterday, and was able to incorporate changes to a much larger project, and it appears to be working great. Since this was a simple project I modified the project to be a little more complex. In the end this worked great.
Thanks for the help, and thanks for the last message.
private void XamDataGrid1_CellChanged(object sender, Infragistics.Windows.DataPresenter.Events.CellChangedEventArgs e) { switch (e.Cell.Field.Name) { case "String_Value2": lblState.Content = "String_Value2 Changed"; break; case "Boolean_Value": if ((e.Editor as XamCheckEditor).IsChecked == true) { lblState.Content = "Boolean_Value Checked"; } else if ((e.Editor as XamCheckEditor).IsChecked == false) { lblState.Content = "Boolean_Value Unchecked"; } break; case "Boolean_Value2": if ((e.Editor as XamCheckEditor).IsChecked == true) { lblState.Content = "Boolean_Value2 Checked"; } else if ((e.Editor as XamCheckEditor).IsChecked == false) { lblState.Content = "Boolean_Value2 Unchecked"; } break; default: break; } }
Hello air1kdf,
I am just checking if my last reply was helpful for you.
If you require any further assistance please do not hesitate to ask.
I have been looking into your post and I understood that you wish if an user checks/unchecks a checkbox, some action happens and the scroll wheel does not interfere with the state of the checkbox. I am sending you a modified version of your project(scroll_modified.zip) where this functionality is achieved by handling the event ‘CellChanged’ instead of ‘ValueChanged’.
If you need any further assistance, feel free to ask.
What you are saying does not work that way in my example. I'll just explain what I want, and you can give me an example of how this can be accomplished.
I have a collection of items, some of the data types are boolean. I want to see checkboxes in the grid for boolean values. When the user changes from checked to unchecked, I would like to do something with all the data in that row (say console.writeline). The state of the collection must also match what's in the grid. And the scroll wheel must not interfere with the state of the checkbox.
Simple, and I'm positive that this would benefit others as well.
