1060
Conditional Numeric YAxis in percentage
We are using XamDataChart in our WPF (MVVM) appliation and everything is working fine. However we need to plot (sometimes) item which has values in Percentage. You can say, we have a dropdown above the chart from which user select, which values will be plotted in Chart.
I know, for showing the percentage "%" value in Y-Axis we have to set Label="{}{:P1}".
So my question is that how can I handle it through binding with my Model, on conditional basis?
  • 30692
    Suggested Answer
    If the chart has a data context to bind against you could try binding the y axis's label property against a string in your view model that either contained the percentage format string or not, depending on the situation.
    -Graham
