I have a simple base class to handle my property changed events. I am using this for several classes without issue. I'm getting a null reference exception on the 'RaiseEvent PropertyChanged' line. When I look at 'strPropertyName' and 'Me' everything appears to be valid. I looked at the property that is triggering this to see if somehow it was being set to nothing by putting in a simple
If propertyname is nothing then
dim foo as integer
End if
on the get and set with a breakpoint on the 'dim foo' line and it never is hit. The top line of the stack trace seems to have properties referring to the row and column position if I understand it correctly. Looking at my data class when the exception occurs the info to set the row and column position of that particular tile item is there. If anyone has any idea what the issue is I would really appreciate some help.
Base Class
Public Class ViewModelBase Implements INotifyPropertyChanged Public Event PropertyChanged(ByVal sender As Object, ByVal e As System.ComponentModel.PropertyChangedEventArgs) _ Implements System.ComponentModel.INotifyPropertyChanged.PropertyChanged Protected Sub OnPropertyChanged(ByVal strPropertyName As String) If Me.PropertyChangedEvent IsNot Nothing Then RaiseEvent PropertyChanged(Me, New System.ComponentModel.PropertyChangedEventArgs(strPropertyName)) End If End Sub
Stack Trace
at Infragistics.Windows.Internal.TileManager.ItemRowColumnSizeInfo..ctor(ItemInfoBase info, Int32 row, Int32 column, Rect targetRect, Size preferredSize) at Infragistics.Windows.Internal.TileManager.GetItemRowColumnSnapshotHelper(List`1 list, LayoutItemsCollection layoutItems, Nullable`1 explicitRow, Nullable`1 explicitColumn) at Infragistics.Windows.Internal.TileManager.GetItemRowColumnSnapshot() at Infragistics.Windows.Internal.TileManager.OnArrange(Boolean& itemLocationsAreaTheSame, Boolean& inViewItemsAreTheSame) at Infragistics.Windows.Tiles.TilesPanelBase.ArrangeOverride(Size finalSize) at Infragistics.Windows.Tiles.TilesPanel.ArrangeOverride(Size finalSize) at System.Windows.FrameworkElement.ArrangeCore(Rect finalRect) at System.Windows.UIElement.Arrange(Rect finalRect) at System.Windows.ContextLayoutManager.UpdateLayout() at System.Windows.UIElement.UpdateLayout() at Infragistics.Controls.Charts.MarkerSeries.<UpdateMarkerTemplates>b__7a(Marker m) at Infragistics.Controls.Charts.Util.HashPool`2.DoToAll(Action`1 action) at Infragistics.Controls.Charts.ScatterBase.DoToAllMarkers(Action`1 action) at Infragistics.Controls.Charts.MarkerSeries.UpdateMarkerTemplates() at Infragistics.Controls.Charts.MarkerSeries.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue) at Infragistics.Controls.Charts.ScatterBase.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue) at Infragistics.Controls.Charts.ScatterLineSeries.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue) at Infragistics.Controls.Charts.Series.<.ctor>b__3(Object o, PropertyUpdatedEventArgs e) at Infragistics.Controls.Charts.Series.RaisePropertyChanged(String propertyName, Object oldValue, Object newValue) at Infragistics.Controls.Charts.MarkerSeries.<.cctor>b__8b(DependencyObject sender, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at Infragistics.Controls.Charts.MarkerSeries.set_ActualMarkerTemplate(DataTemplate value) at Infragistics.Controls.Charts.MarkerSeries.UpdateIndexedProperties() at Infragistics.Controls.Charts.ScatterBase.UpdateIndexedProperties() at Infragistics.Controls.Charts.MarkerSeries.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue) at Infragistics.Controls.Charts.ScatterBase.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue) at Infragistics.Controls.Charts.ScatterLineSeries.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue) at Infragistics.Controls.Charts.Series.<.ctor>b__3(Object o, PropertyUpdatedEventArgs e) at Infragistics.Controls.Charts.Series.RaisePropertyChanged(String propertyName, Object oldValue, Object newValue) at Infragistics.Controls.Charts.MarkerSeries.<.cctor>b__89(DependencyObject sender, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.Activate(Object item) at System.Windows.Data.BindingExpression.OnDataContextChanged(DependencyObject contextElement) at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.Activate(Object item) at System.Windows.Data.BindingExpression.OnDataContextChanged(DependencyObject contextElement) at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.TreeWalkHelper.OnInheritablePropertyChanged(DependencyObject d, InheritablePropertyChangeInfo info) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.Activate(Object item) at System.Windows.Data.BindingExpression.OnDataContextChanged(DependencyObject contextElement) at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.Controls.ContentPresenter.OnContentChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.StyleHelper.InvalidateDependents(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, FrugalStructList`1& dependents, Boolean invalidateOnlyContainer) at System.Windows.StyleHelper.OnTriggerSourcePropertyInvalidated(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, DependencyPropertyChangedEventArgs changedArgs, Boolean invalidateOnlyContainer, FrugalStructList`1& triggerSourceRecordFromChildIndex, FrugalMap& propertyTriggersWithActions, Int32 sourceChildIndex) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.Tiles.Tile.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.Controls.ContentControl.set_Content(Object value) at Infragistics.Windows.Tiles.TilesPanel.OnItemsChanged(Object sender, ItemsChangedEventArgs args) at System.Windows.Controls.VirtualizingPanel.OnItemsChangedInternal(Object sender, ItemsChangedEventArgs args) at System.Windows.Controls.Panel.OnItemsChanged(Object sender, ItemsChangedEventArgs args) at System.Windows.Controls.ItemContainerGenerator.OnRefresh() at System.Windows.Controls.ItemContainerGenerator.OnCollectionChanged(Object sender, NotifyCollectionChangedEventArgs args) at System.Windows.Controls.ItemContainerGenerator.System.Windows.IWeakEventListener.ReceiveWeakEvent(Type managerType, Object sender, EventArgs e) at System.Windows.WeakEventManager.DeliverEventToList(Object sender, EventArgs args, ListenerList list) at System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args) at System.Collections.Specialized.CollectionChangedEventManager.OnCollectionChanged(Object sender, NotifyCollectionChangedEventArgs args) at System.Collections.Specialized.NotifyCollectionChangedEventHandler.Invoke(Object sender, NotifyCollectionChangedEventArgs e) at System.Windows.Data.CollectionView.OnCollectionChanged(NotifyCollectionChangedEventArgs args) at System.Windows.Controls.ItemCollection.System.Windows.IWeakEventListener.ReceiveWeakEvent(Type managerType, Object sender, EventArgs e) at System.Windows.WeakEventManager.DeliverEventToList(Object sender, EventArgs args, ListenerList list) at System.Windows.WeakEventManager.DeliverEvent(Object sender, EventArgs args) at System.Collections.Specialized.CollectionChangedEventManager.OnCollectionChanged(Object sender, NotifyCollectionChangedEventArgs args) at System.Windows.Data.CollectionView.OnCollectionChanged(NotifyCollectionChangedEventArgs args) at System.Windows.Data.ListCollectionView.RefreshOverride() at System.Windows.Data.CollectionView.Refresh() at System.Windows.Data.CollectionView.EndDefer() at System.Windows.Data.CollectionView.DeferHelper.Dispose() at System.Windows.Controls.ItemCollection.SetCollectionView(CollectionView view) at System.Windows.Controls.ItemCollection.SetItemsSource(IEnumerable value) at System.Windows.Controls.ItemsControl.OnItemsSourceChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at Infragistics.Windows.Virtualization.RecyclingItemsControl.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.Activate(Object item) at System.Windows.Data.BindingExpression.OnDataContextChanged(DependencyObject contextElement) at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.TreeWalkHelper.OnInheritablePropertyChanged(DependencyObject d, InheritablePropertyChangeInfo info) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.Activate(Object item) at System.Windows.Data.BindingExpression.OnDataContextChanged(DependencyObject contextElement) at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.TreeWalkHelper.OnInheritablePropertyChanged(DependencyObject d, InheritablePropertyChangeInfo info) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.Activate(Object item) at System.Windows.Data.BindingExpression.OnDataContextChanged(DependencyObject contextElement) at System.Windows.Data.BindingExpression.HandlePropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpressionBase.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.Data.BindingExpression.OnPropertyInvalidation(DependencyObject d, DependencyPropertyChangedEventArgs args) at System.Windows.DependentList.InvalidateDependents(DependencyObject source, DependencyPropertyChangedEventArgs sourceArgs) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.TreeWalkHelper.OnInheritablePropertyChanged(DependencyObject d, InheritablePropertyChangeInfo info) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkLogicalChildren(FrameworkElement feParent, FrameworkContentElement fceParent, IEnumerator logicalChildren) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1._VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.VisitNode(FrameworkElement fe) at System.Windows.DescendentsWalker`1.VisitNode(DependencyObject d) at System.Windows.DescendentsWalker`1.WalkFrameworkElementLogicalThenVisualChildren(FrameworkElement feParent, Boolean hasLogicalChildren) at System.Windows.DescendentsWalker`1.IterateChildren(DependencyObject d) at System.Windows.DescendentsWalker`1.StartWalk(DependencyObject startNode, Boolean skipStartNode) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.Controls.ContentPresenter.OnContentChanged(DependencyObject d, DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.StyleHelper.InvalidateDependents(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, FrugalStructList`1& dependents, Boolean invalidateOnlyContainer) at System.Windows.StyleHelper.OnTriggerSourcePropertyInvalidated(Style ownerStyle, FrameworkTemplate frameworkTemplate, DependencyObject container, DependencyProperty dp, DependencyPropertyChangedEventArgs changedArgs, Boolean invalidateOnlyContainer, FrugalStructList`1& triggerSourceRecordFromChildIndex, FrugalMap& propertyTriggersWithActions, Int32 sourceChildIndex) at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e) at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args) at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType) at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp) at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange) at System.Windows.Data.BindingExpression.ScheduleTransfer(Boolean isASubPropertyChange) at MS.Internal.Data.ClrBindingWorker.NewValueAvailable(Boolean dependencySourcesChanged, Boolean initialValue, Boolean isASubPropertyChange) at MS.Internal.Data.PropertyPathWorker.UpdateSourceValueState(Int32 k, ICollectionView collectionView, Object newValue, Boolean isASubPropertyChange) at MS.Internal.Data.ClrBindingWorker.OnSourcePropertyChanged(Object o, String propName) at MS.Internal.Data.PropertyPathWorker.System.Windows.IWeakEventListener.ReceiveWeakEvent(Type managerType, Object sender, EventArgs e) at System.Windows.WeakEventManager.DeliverEventToList(Object sender, EventArgs args, ListenerList list) at System.ComponentModel.PropertyChangedEventManager.OnPropertyChanged(Object sender, PropertyChangedEventArgs args) at SES_Tire_Analyzer.ViewModelBase.OnPropertyChanged(String strPropertyName) in C:\Users\Russ\Desktop\SES Tire AnalyzerV3\SES Tire Analyzer\SES Tire Analyzer\ViewModel\ViewModelBase.vb:line 16 at SES_Tire_Analyzer.VehicleModeVM.set_SelectedAnalysis(VehicleAnalysisBase value) in C:\Users\Russ\Desktop\SES Tire AnalyzerV3\SES Tire Analyzer\SES Tire Analyzer\ViewModel\VehicleModeVM.vb:line 116 at SES_Tire_Analyzer.VehicleModeVM.UpdateDisplayedAnalysis() in C:\Users\Russ\Desktop\SES Tire AnalyzerV3\SES Tire Analyzer\SES Tire Analyzer\ViewModel\VehicleModeVM.vb:line 734 at SES_Tire_Analyzer.VehicleModeVM._Lambda$__161() in C:\Users\Russ\Desktop\SES Tire AnalyzerV3\SES Tire Analyzer\SES Tire Analyzer\ViewModel\VehicleModeVM.vb:line 57 at GalaSoft.MvvmLight.Command.RelayCommand.Execute(Object parameter) at GalaSoft.MvvmLight.Command.EventToCommand.Invoke(Object parameter) at System.Windows.Interactivity.TriggerBase.InvokeActions(Object parameter) at System.Windows.Interactivity.EventTriggerBase.OnEvent(EventArgs eventArgs) at System.Windows.Interactivity.EventTriggerBase.OnEventImpl(Object sender, EventArgs eventArgs) at System.Windows.Controls.SelectionChangedEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseEvent(RoutedEventArgs e) at System.Windows.Controls.ComboBox.OnSelectionChanged(SelectionChangedEventArgs e) at System.Windows.Controls.Primitives.Selector.InvokeSelectionChanged(List`1 unselectedItems, List`1 selectedItems) at System.Windows.Controls.Primitives.Selector.SelectionChanger.End() at System.Windows.Controls.Primitives.Selector.SelectionChanger.SelectJustThisItem(Object item, Boolean assumeInItemsCollection) at System.Windows.Controls.ComboBox.NotifyComboBoxItemMouseUp(ComboBoxItem comboBoxItem) at System.Windows.Controls.ComboBoxItem.OnMouseLeftButtonUp(MouseButtonEventArgs e) at System.Windows.UIElement.OnMouseLeftButtonUpThunk(Object sender, MouseButtonEventArgs e) at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent) at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e) at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget) at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target) at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs) at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised) at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args) at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args) at System.Windows.UIElement.RaiseEvent(RoutedEventArgs args, Boolean trusted) at System.Windows.Input.InputManager.ProcessStagingArea() at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input) at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport) at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel) at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at System.Windows.Application.Run(Window window) at System.Windows.Application.Run() at SES_Tire_Analyzer.Application.Main() in C:\Users\Russ\Desktop\SES Tire AnalyzerV3\SES Tire Analyzer\SES Tire Analyzer\obj\x86\Debug\Application.g.vb:line 72
I was able to narrow it down to how a binding in my ScatterSeries in the xaml was being done. Still strange to me that the stack trace would be like it was.
Thank you for your post. I have been looking into it but it seems like am missing something about your scenario, so if this is still an issue for you, could you please send me an isolated sample project, where this is reproduced, so I can investigate it further for you.
