After finding the row I just added with my own method (sometimes GetRecordFromDataItem() does not work even when I see the record in the debugger) I set the DataRecord's IsSelected and IsActive properties to true and the ActiveDataItem to the object and set the ActiveRecord to the found DataRecord, and still the newly added row will not scroll into view.
What do I have to do to make that happen?
Thanks.
Hello Mike,
Thanks again.
Hi Stefan. Yes, your answer was very helpful, thank you.
Thank you for your post. I have been looking into it and I suggest you use the XamDataGrid’s BringRecordIntoView method to scroll to the Record you want in view. Please let me know if this helps you or you need further assistance on this matter.
