I am using Infragistics WPF 2012.2
In my application, I use many infragistics components with the theme IGTheme. Everything works great. However, in the last week, I added a XamTabControl and setted its theme to IGTheme. It shows perfectly in VStudio XAML editor. However, when I run the application, the theme disappear and it is white. I tried to change the background color to another color and remove the color, it stays white. There is no code that is modifying the style or the theme except the xaml. On another computer, the theme is showing correctly... I've tried using Windows Classic and Windows 7 OS Theme and it doesn't change anything. Every other controls are showing correctly with the correct theme.....
Do you have any idea what could be the source of this problem?
Thank you!
Hello infragisticsMaster,
I am checking if this is still an issue for you.
If you require any further assistance please do not hesitate to ask.
I have been looking into your post and I assume you are using our NetAdvantage 2011 vol.2. Would you please provide us with an isolated sample application where your issue occurs and the version of the service release that you are using in order to provide you with more accurate assistance.
I am looking forward to hearing from you.
Can you provide us a project which reproduces this behaviour. And the version of our product that you are using(it looks like: 11.2.1012).
Anastas
