405
Binding Errors in Style for NetworkNodeNodeControl
Normal 0 false false false EN-US X-NONE X-NONE
I am attempting to style the nodes based on properties on the "NodeModel".  I have the following code inside the NetworkNodeNodeLayout:
<ig:XamNetworkNode ItemsSource="{Binding Nodes}" >
    <ig:XamNetworkNode.GlobalNodeLayouts>
        <ig:NetworkNodeNodeLayout NodeStyle="{StaticResource NodeStyle}" TargetTypeName="NodeModel"
My NodeStyle looks like the following:
<Style x:Key="NodeStyle" TargetType="ig:NetworkNodeNodeControl">
    <Setter Property="Background" Value="{Binding NodeType, Converter={StaticResource NodeToColorConverter}}"/>
    <Setter Property="Foreground" Value="Black"/>
    <Setter Property="Visibility" Value="{Binding Visible}"/>
</Style>
The "NodeType" and "Visible" bindings in the style are both properties found on the "NodeModel".
When running the program the immediate window spits out a binding error for every single node in the network.
The view has its DataContext set to a viewModel that exposes a "Nodes" property.
You can see this behavior by running the attached project and viewing the immediate window after the view loads.  This is the output that spams:
System.Windows.Data Error: 40 : BindingExpression path error: 'NodeType' property not found on 'object' ''BindingErrorsViewModel' (HashCode=66354235)'. BindingExpression:Path=NodeType; DataItem='BindingErrorsViewModel' (HashCode=66354235); target element is 'NetworkNodeNodeControl' (Name=''); target property is 'Background' (type 'Brush')
System.Windows.Data Error: 40 : BindingExpression path error: 'Visible' property not found on 'object' ''BindingErrorsViewModel' (HashCode=66354235)'. BindingExpression:Path=Visible; DataItem='BindingErrorsViewModel' (HashCode=66354235); target element is 'NetworkNodeNodeControl' (Name=''); target property is 'Visibility' (type 'Visibility')
QUESTION:
Why are there binding failures?  Why is the NodeStyle looking to the view model for the properties Visible and NodeType instead of using the NodeModel's properties?
Kind Regards,
Daniel
PS Let me know if a support ticket would be a better option.
NetworkNodeIssues.zip
