I need to change the default order of column, as i use ObservableCollection<> as datasource, when i try to change the order using <FieldLayout>, I get the following error
"Can't set the DataSource on a DataPresenter that has items added explicitly through the DataItems collection."
Can somebody give me help
Is this a very difficult task, so no one is able to answer?
