425
Drag and Drop "Hit Zone"
I am using XamDataTree. Evertything works now as expected except this problem :
When I drag a node over another node, I absolutely need to be at the exact position where there is the text of the node even if the height of the node is bigger. It is very hard for the user to always leave the mouse cursor exactly over the text and most of the time, he leaves the cursor just a few pixels higher or lower than the text. I see that the hit zone works fine with the current over node where the mouse is. The node has a colored background that appears as soon as the cursor is in the bound of the node size, however, the line has a colored background only when the cursor is exactly over the text.
I am using a custom NodeLayout :
with the ItemTemplate as follow :
<ig:NodeLayout.ItemTemplate>
                        <DataTemplate>
                            <TextBlock Text="{Binding Data.Name}" Foreground="{Binding Data.FgColor}" Background="{Binding Data.BgColor}">
                            </TextBlock>
                        </DataTemplate>
 </ig:NodeLayout.ItemTemplate>
I've tried to use stackpanel, label, rectangle, force height, etc.. nothing works for drag at the moment.
Thank you!
