I have a small project document management.
way many are proposing and I do not know how start.
What is the best control : datagrid , datapresenter , datapivot ...........
Thank you for your advice and links to examples.
CaisseOdeV
Thank you for your reply. Please let me know if I can assist you further on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Thank you for this links.
I spend several days to fully understand and test. I'll let you know.
Cordialement Caisseodev
Hello CaisseOdeV,
Thank you for your post. I have been reading through it and the best control depends on the data that you wish to display. I if you wish to display. Using the DataPresenter controls, you can display data such as DataTables and collection of objects. You can read more detailed information of which types of data you can use with our data presentation controls, here in our online documentation: http://help.infragistics.com/NetAdvantage/WPF/2011.2/CLR4.0/?page=xamDataPresenter_Accessing_Data.html
The XamPivotGrid control is a data summarization and information visualization tool and it allows you to build complex business analysis applications. The control supports several data sources that can used in order to display the information that you need. You can read more information regarding XamPivotGrid at the following articles: http://help.infragistics.com/NetAdvantage/WPFDV/2011.2/CLR4.0/?page=xamPivotGrid_Understanding_xamPivotGrid.html, http://help.infragistics.com/NetAdvantage/WPFDV/2011.2/CLR4.0/?page=xamPivotGrid_Using_xamPivotGrid.html
Please let me know if you need any further assistance on the matter.
