60
TabGroupPane using ContentPaneFactory
I am currently working with the ContentPaneFactory to generate ContentPanes and display them in a TabGroupPane.  The code below results in nothing rendered for this portion of the control.  I know the data is there, because if I remove the TabGroupPane (i.e. just have PaneFactory inside of the SplitPane), I see multiple panes tiled with the content in place.  Can anyone point me in the right direction with this problem?
<igDock:SplitPane Name="m_oPropertyDock"
                              igDock:XamDockManager.InitialLocation="DockedRight"
                              SplitterOrientation="Vertical"
                              Visibility="Visible"
                              Margin="0,18,5,0"
                              HorizontalAlignment="Stretch">
                <igDock:SplitPane.DataContext>
                    <local:PropertyViewModel/>
                </igDock:SplitPane.DataContext>
                <igDock:TabGroupPane>
                    <igExtensions:ContentPaneFactory.PaneFactory>
                        <igExtensions:ContentPaneFactory ItemsSource="{Binding Path=CustomPropertyContent, Mode=OneWay}"
                                                             HeaderPath="Name"
                                                             ContentPath="Content">
                            <igExtensions:ContentPaneFactory.ContainerStyle>
                                <Style TargetType="igDock:ContentPane">
                                    <Setter Property="AllowPinning" Value="False"/>
                                </Style>
                            </igExtensions:ContentPaneFactory.ContainerStyle>
                        </igExtensions:ContentPaneFactory>
                    </igExtensions:ContentPaneFactory.PaneFactory>
                </igDock:TabGroupPane>
            </igDock:SplitPane>
Also, CustomPropertyContent is a list of objects that have two files, string Name and ContentControl Content.
  • 54937
    Its hard to say from the snippet provided. Maybe you could post a sample that demonstrates the issue so we can debug it and see what is happening?
