470
11.2 Datagrid shows only date
I tried to bind a DataTime Field of Datatable to a field. Autogenerate is false. field is defined as:
<igDP:Field Name="Created" Label="{DynamicResource ucCylinderMove_Field_Created.Label}">
                            <igDP:Field.Converter>
                                <Converters:FullDateTimeConverter />
                            </igDP:Field.Converter><igDP:Field.Settings>
                                <igDP:FieldSettings AutoSizeScope="ViewableRecords" AutoSizeOptions="DataCells" AllowEdit="False" />
                            </igDP:Field.Settings>
As You can see I also have tried to use a converter to display the missing time, but it is still missing time portion.
I also tried to use a datetimeeditor but the same result.
If I look into the datafield it is holding date and time.
What could be wrong with it?
  • 30945
    I am very glad that you have managed to solve the issue that you were having. Please let me know if you need any further assistance on the matter.
    Sincerely,
    Krasimir
    Developer Support Engineer
    www.infragistics.com/support
  • 470
    Verified Answer
    I found the solution !
    For all are interested or having an equivalent problem this helps:
        <igDP:FieldSettings AutoSizeScope="ViewableRecords" AutoSizeOptions="DataCells" AllowEdit="False" EditAsType="{x:Type sys:DateTime}">
          <igDP:FieldSettings.EditorStyle>
    	 <Style TargetType="{x:Type igEditors:XamDateTimeEditor}" >
    	  <Setter Property="Mask" Value="{}{date} {longtime}" />
    	 </Style>
          </igDP:FieldSettings.EditorStyle>
        </igDP:FieldSettings>
    </igDP:Field>
