Hello!
I'm working on a chart containing between 24 and 300 datapoints. If my collection of points is greater than 200, I've got a XAML error:
I'm working on a .NET 3.5 application and I don't have CLR4 with XamDataChart. I use currently Infragistics WPF3 version 10.3.
Any suggestion about displaying my chart ? I join a sample project to illustrate my case.
Patrick
Hello Patrick,
I am very glad that my reply was helpful for you. Please let me know if you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Hello Krasimir,
Thank you very much. The limit on grid lines, and not on data points, was the piece of data that I missed to finish my chart!
Hello Patrik,
I have been looking into the behavior that you have describe and it seems that it is caused by the fact that when there are more the 199 data points in a series, the XamChart cannot draw the vertical grid lines, since there is no enough free space for that. In order to avoid this behavior I can suggest setting the Unit property of the PrimaryX axis of the XamChart to a value that will decrease the grid lines count. I have modified the sample application that you have attached in order to demonstrates how you can implement the described approach.
