I'm simply looking to generate a multipage report but I'm doing something wrong. Using the code below I get an 'Specified element is already the logical child of another element. Disconnect it first.' error on the ' pp.xamReportPreview1.GeneratePreview(Report, False, True)' line. If I comment out either of the bolded lines then it works fine. I haven't had any luck searching around the forum or looking through the user manuals on how to create a multipage report.
Public Shared Sub PrintPreview() Dim Report As New Report Dim Section1 As New EmbeddedVisualReportSection(New TextBlock) Dim Section2 As New EmbeddedVisualReportSection(New TextBlock) Report.Sections.Add(Section1) Report.Sections.Add(Section2)
Report.PageFooter = New TextBlock() With {.Text = My.Application.Info.Description & My.Application.Info.Version.ToString & " - CONFIDENTIAL INFORMATION - " & DateTime.Now.ToString, .VerticalAlignment = VerticalAlignment.Top, .FontSize = 8} Report.ReportSettings.PageOrientation = PageOrientation.Landscape Report.ReportSettings.HorizontalPaginationMode = HorizontalPaginationMode.Scale Report.PageHeader = New TextBlock() With {.Text = My.Settings.TeamName, .VerticalAlignment = VerticalAlignment.Bottom, .TextAlignment = TextAlignment.Center, .FontWeight = FontWeights.Bold, .FontSize = 14}
Dim pp As New PrintPreview pp.xamReportPreview1.GeneratePreview(Report, False, True) pp.ShowDialog() End Sub
Thank you for your post. I have been looking into it and the code you have provided and I suggest you set the Page Footer and Header to every section instead of to the Report directly. Please let me know if this helps you or you need further assistance on this matter.
