Hi *,
is there a way to add a help button between the title bar and the ribbon? If you look at Office 2007, there's an help icon on the right hand side.
thx
fabian
Thank you! This is exactly what I and others have been looking for. This is perfect.
Actually, this feature is supported (and built-in) by using the TabIteAreaToolbar. This toolbar allows you to pace any element, in your case a help button, to the right of the ribbon tabs just like you would expect in Office. This feature was added for this specific scenario.
Hello Jason,
Still this feature is not built in, but If you want to add buttons in the XamRibbonWindow's TitleBar you can see this forum thread:
http://ko.infragistics.com/community/forums/t/25725.aspx
where is explained how to do so. You can also see the sample in the Samples Browser under xamRibbon \ Display \ Tab Item Area Toolbar section, where it is explained how to add items at the right end of the xamRibbon's tab area. You can also suggest this feature as new product idea here:
http://ideas.infragistics.com/
Is there any update on this? Is this product still being maintained? We need a proper XAML solution to this, not a workaround in code.
Thank you for your post. I have been looking into it and I can say that still there is no built in functionality for help button, so I can suggest you use the workaround from the earlier posts of this thread.
