Hi.
I want to set only max length of the XamMaskedEditor the control only 30 chars using mask property only.
igDP:FieldSettings.EditorStyle>
<Style TargetType="{x:Type igEditors:XamMaskedEditor}">
<Setter Property="Mask" Value=""/>
</Style>
</igDP:FieldSettings.EditorStyle>
Can any guide me what value of mask property need to set?
I had a similar issue where I needed to limit a field to only numeric and no more than 32 characters in length, When I tried this:
<Setter Property="Mask" Value="{}{char:32:0-9}" /> I received this error if I entered 10 characters or more when .
When I changed it to this:
<Setter Property="Mask" Value="{}>{char:32:0-9}" />It worked correctly. Do you know why the first one gives me an error but the second one works?
Thanks,Jeff
Thanks again.
yes, it did.
thanks.
Thank you for your post. I have been looking into it and I can suggest you add the following Setter to your Style:
<Setter Property="ValueConstraint"> <Setter.Value> <igEditors:ValueConstraint MinLength="2"/> </Setter.Value> </Setter>
Hope this helps you.
this post looks like the closest one to the problem I am having setting the minimum length:
in my UnboundField, I am setting a <Style> of type XamMaskedEditor of infragistics, like this:
<igDP:UnboundField.Settings> <igDP:FieldSettings EditorType="{x:Type igEditors:XamMaskedEditor}" > <igDP:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamMaskedEditor}" > <Setter Property="Mask" Value="{}{char:50:0-9a-zA-Z _}"/> ... </Style> </igDP:FieldSettings.EditorStyle> </igDP:FieldSettings> </igDP:UnboundField.Settings>
as you can see, the maximum length of the field is 50 characters, but I cannot set the minimum length that is 2.
I would like to use the ValueConstraint property, but don't know how.
could you please, advise?
thanks,
