After typing into the XamTextEditor and hitting the enter key, the keyboard focus does not stay with the XamTextEditor control. It hasn't completely passed to the next control either. If seems like it still has visual focus (i.e. the style shows a focused style). I can no longer type in the XamTextEditor. How do I force it to retain keyboard focus.
I am very glad that the approach that I have suggested was helpful for you. Please let me know if you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Using StartEditMode seemed to work.
Thank you for your post. I have been reading through it and the behavior that you are describing seems expected. When enter key is pressed the XamTextEditor exits edit mode and it is still on focus. You can start typing again in the editor after pressing the F2 key which puts the XamTextEditro into edit mode. I assume that you wish to be able to enter edit mode when pressing any key while the XamTextEditor is on focus. If my assumption is correct, I can suggest handling the KeyDown event and itf the editor is not in edit mode to call the StartEditMode method. Also you can set the IsAlwaysInEditMode property of the XamTextEditor to True in order to be able to type after enter key is pressed.
I have created a sample application for you which demonstrates the first approach that I have described.
