i am using a xamDataGrid and trying to bind it to following new hierarchical data:
WorkListItem: ... int DocumentCount List of Documents Document: string Comment string DocumentState to
the DataSource is bind to List<WorkListitem>
It works but now i want to collapse the children collection (Documents) but it doesnt´t work. I have tried it with another hierarchical data which is more complicated than this one and it works with the same datagrid settings (FieldLayoutSettings etc) . Does it depends on the relation between Document and WorkListItem ? I can´t find out the difference between the hierarchical structures.
Hase
best regards from germany
Hello Hase,
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you for your post. I have been looking into it and I created a sample project for you using structure you have provided and everything seems to work ok on my side. If the sample doesn’t satisfies all your needs feel free to modify it, so it reproduces your behavior and send it back to me for further investigation.
