Hello I'm trying to use an editable ComboEditorTool but I want it to only take integers and to show commas on the thousands (9,999,999,999,999) is there a built in way to do this? If not, how can I achieve it?
Edit:Also, on a slightly related topic. How can I disable auto-complete when the user types on the combobox? We don't want to change the selection based on the users input.
Thanks.
I have modified the sample I sent you before so now it uses the Styles from 10.1 and you should be able to build it. You just need to add the assemblies again.
Hope this helps you.
Sorry I should've mentioned this before. We're using version 10.1.20101.1000, we haven't bought the latest version yet (not sure if we will), I couldn't compile your solution, but I did try setting "IsTextSearchEnabled" to false in a style and I get an error that says:
"Unhandled exception: 'Set property 'System.Windows.FrameworkElement.Style' threw an exception' Line Number X and line position Y".
Line X and position Y is where the style I mentioned above is.
Lmk, thanks!
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I created a Style for the ComboEditorTool’s ComboBoxStyle and set its IsTextSearchEnabled to False and copied its default Template and replace the TextBlock with XamMaskedEditor. In the App.xaml file you can see the Style and set the Mask of the Editor to the one you want. Please let me know if this helps you or you need further assistance on this matter.
