HI,
I have been looking at using your xamComboEditor with filtering and have identified what I believe to be a bug. In your combo box you appear to use the Popup with relative placement. By default the Popup appears under the control unless there is not enough screen space, in which case it appears above the control, as expected. A problem occurs due to the filtering. When clearing text in the control which would result in more items appearing in the Popup, the placement always changes to below the control, rather than the appropriate placement for the screen position. The result of this is that if Popup is above the control (because it will not fit below), when the Popup expands it attempts to place it below, but instead will go as low as possible, resulting in the control being covered by the Popup. This is clearly an unacceptable user experience, so needs to be addressed.
This problem can be observed on your own xamFeatureBrowser shipped with NetAdvantage for WPF. Go to the xamComboEditor -> Key Features -> Read-Only And AutoComplete. On the “Google Suggest Style – filtered items list” combo, and type ‘a’, then delete the ‘a’. You will see the Popup expand to show entries beginning with ‘a’, and the Popup expand over the control when the ‘a’ is deleted. If you don’t observe this then move the application to the bottom of the screen before you type in the combo.
Could you please suggest any work-around, until this is fixed, to provide acceptable usability. I attempted to create and use a custom Popup in the template for your control, but the CustomPopupPlacementCallback does not appear to get called when the Popup expands and is moved to below the control (note I was forcing Custom placement before the open of the Popup).
Thanks for your time.
In which version is this issue fixed? I am using 13.2 and the issue is still there. I have attached a sample project. When you type "6" and delete it, the popup hides the control.
Thanks.
The development issue with ID of 101860 has been fixed and it is available in the latest Service Release. You can download the Service Release by logging in our web site and then going to Account\My Keys and Downloads page.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Thank you for your post. I have logged this behavior with our developers in our tracking system, with an issue ID of 101860. I have also created a support ticket on your behalf with number CAS-87486-NNT501 in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Infragistics, Inc.
