I have a question on the XamDataGrid. I have a datetiem column in the grid. This column's GroupByMode is set to OutlookDate. When I use this column as the group by field. The data rows are grouped by Today, Yesterday and Tuesday. However, the item count is not shown. Is any way to show the item count? The following is a snapshot of the grid.
s correct i have solved this issue.....
You can check whether the description of the GroupByRecord already contains Items'Count and if it does, you won't modify the description.
Thanks for giving nice solution but i am facing problem in that.When ever i scroll down "GroupByRecordPresenter" is loaded and items are doubling.How can i stop this? i am sending an image my problem.
Hello William,
Thanks again.
Thanks. Your suggestion works fine. The problem is solved.
William
