Hi All -
We are using NetAdvantage for Win Client 2009 Vol 1with the latest hotfix (NetAdvantage_WPF_20091.2196) applied.
We are experiencing a significant memory leak with passing Bitmap images to the XamDataCarouselcontrol. Around 4 MB per image (HD images).
It worked fine when installed on XP 32 bit but the leak appeared when using on Win 7 64 bit and .NET 3.5. No code was changed. Below is a code snippet. Does anyone have any ideas why this might be happening?
BitmapImage bmpImage = new BitmapImage();bmpImage.BeginInit();bmpImage.CreateOptions = BitmapCreateOptions.IgnoreImageCache;bmpImage.UriSource = new Uri(strbitmapPath);bmpImage.CacheOption = BitmapCacheOption.OnLoad;bmpImage.EndInit();if (bmpImage.CanFreeze){ bmpImage.Freeze();}((System.Windows.Controls.Image)objStillsUserControl.FindName("image1")).Source = bmpImage;albumCarousel.DataItems.Add(objStillsUserControl);In above code objStillsUserControl is a UserControl which is added in the XamDataCarousel object "albumcarousel".
-Gregg
Hello Gregg,
I will look forward to hear from you.
Hi Stefan -
Thanks so much for your help offer. Currently we are investigating other alternatives. I'll let you know if we want to pursue this further.
Thank you for your post. I have been looking into it, but it seems like am missing something about your scenario, so could you please profile your project with ANTS memory profiler( for example) and send me screenshots of the results you get if there is memory leak and also your sample project, where this is reproduced, so I can investigate it further for you.
