This bug occurs if the active ContentPane, i.e. the ContentPane is currently displayed in the DocumentContentHost's ContentArea belongs to the rightmost visible Tab on the DocumentContentHost's TabStrip.
If I reduce the width of the DocumentContentHost, the Tab belonging to the active ContentPane disappears from the TabStrip (because it was the rightmost) leaving me with a DocumentContentHost displaying a Set of inactive Tabs and a ContentPane belonging to a tab thats not visible.
I attached a Screenshot showing the bug in an example from xamFeatureBrowser. As you can see 'Document Pane #3' is active ('Document Content #3' is visible) but not displayed in the TabStrip.
Hello rmrop,
I would like to let you know that that this issue has been already fixed in the latest service release for 11.1 and up.
If you have any other questions with this matter please feel free to let us know.
Thank you for your answer.
I would like to let you know that due to our product life cycle, this issue will be fixed in NetAdvantage11.1 and up, so in order to have the fix you would have to use one of the versions having it.
In the following link you could find our product life cycle:
http://ko.infragistics.com/support/documentation.aspx#ProductLifecycle
Please let me know if you have any further questions regarding the discussed matter.
Sincerely,
Ekaterina
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
Hello Ekaterina,
I'm using Infragistics 10.3.20103.2250
Regards
I have logged this behavior with our developers in our tracking system, with an issue ID of 108266. I have also created a support ticket on your behalf with number CAS-88225-LR11NK in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Sincerely ,
I have been looking into your issue and can you please give me information on with specific version if our control are you using?
I will be looking forward to hearing from you.
