How to disable data scrolling when I click the date in monthPrev and month Next at XamMonthCalendar with groupmode?
Hello user12341234,
I am glad that you have manage to find a solution.
Is the issue still standing for you? In case of other concerns I will be glad to assist you
Sincerely,
Ekaterina
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
When IsLeadingGroup ="True"
When IsLeadingGroup ="False"
in this case, Setting IsLeadingGroup ="True" will cause the null data month. it seem not good enough.
luckily I found that I can use referrenceday property to set the active date in the middle main calendar.
I have received an update from the developers team.
In this example from the Feature Browser that we have discussed previously, the two small CalendarItemGroups are with properties IsLeadingGroup and IsTrailingGroup set to true for the first and second respectively. This means that those calendar groups are given less priority. There are cases where months should be given less priority and allowed to be empty, such as when showing a small preview of the previous and/or next month. When IsLeadingGroup or IsTrailingGroup is set to true, the CalendarBase will ignore these groups when adjusting/calculating the reference date and therefore these groups may be empty.
This said, in case you want to have today date selected in the big CalendarItemGroup, you can keep IsLeadingGroup and IsTrailingGroup set to true and not set the AllowLeadingAndTrailingGroupActivation to true.
Please let me know if you have further questions regarding the discussed matter.
I have logged this behavior with our developers in our tracking system, with an issue ID of 110713. I have also created a support ticket on your behalf with number CAS-88238-0TXSCY in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Hi user12341234 ,
I was looking into your issue and I have contacted the developers team for additional information.
I will follow up with you as soon as I have feedback from them.
Infragistics Inc .
