We are using Xamgrids for displaying large number of rows, now the problem is with conditional formatting and FormatString .
We have applied conditional formatting like negative value should be displayed in red and format function of textcolumn to display a decimal up to certain decimal places
Now if I scroll from top to bottom, I can see negative numbers without red font and text columns without formatted decimal places data
This problem goes away if I move scroll bar and take particular row in and out of focus
Could you please explain the behavior described above and propose a solution?
Vikram
Hello Ishraque,
Thank you for your feedback. I believe that other community members may benefit from this as well.
Thanks again.
I think you grid is virtualized. Try to change the RecordContainerGenerationMode and test the scrolling
<igWpf:XamDataGrid RecordContainerGenerationMode="LazyLoad"/>
If the problem is solved with the above change then
1. Remove the RecordContainerGenerationMode.
2. Define a cellvaluepresenter style for that field.
<Style x:Key="CheckCellValuePresenterStyle" TargetType="{x:Type igDp:CellValuePresenter}" BasedOn="{StaticResource GeneralCvpStyle}">
<Setter Property="Template">
<Setter.Value>
<ControlTemplate>
<igEditors:XamNumericEditor Value="{Binding RelativeSource={RelativeSource TemplatedParent}, Path=Value}"
Style="{DynamicResource ToggleCheckEditorStyle}" Margin="1,2,1,2" Padding="0"/>
</ControlTemplate>
</Setter.Value>
</Setter>
</Style>
3. Assign this cellvaluepresenter style to the field having the issue.
I hope this will help
Ishraque Tanveer Khan
Hello Vikram,
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
I have been looking into your issue and the behavior you describe is familiar. This usually happens when you have not set your ShouldRefreshOnDataChanged to True, or when your underlying object does not implement INotifyPropertyChanged. In such cases there is nothing to update the evaluate method of the rule for the new value, however when you scroll up and down the XamGrid’s virtualization kicks in, which actually reuses the cells visual elements. This is done in order to drastically improve performance, by generating visuals only for the visible cells. This results in reloading the cells when they move into view and the condition is recheck and the evaluate method of the rule is executed and sets the StyleToApply style.
Hope this clarifies things. Please let me know if I can be of any further assistance on the matter.
