Hi
I am using a datatable to bind the labels of X and Y Axis.In ColumnChart,for the Xaxis,it is not populating all the label values for the XAxis.If the datatable is having more than 10 labels,its showing alternative labels.
eg:if it is like all the months from Jan to Dec...XAxis is having alternative Months like after Jan,its MAR
Please Help
HelloYejjalasomu,
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Hi, if you set the Interval on the xAxis to 1, it will show all the labels. But keep in mind, that if you add lots of data to the chart, you may not want every label to display.
You may also want to increase the extent on the xaxis, so that it can stagger the labels if they begin to collide with one another.
-Graham
