78
Custom Theme Pack - GroupByArea
I am creating a custom theme pack according to the direction in the online help.  I used the default theme files shipped.  For some reason it will not pick up any changes I make to the GroupByArea style.
Is there a bug or some trick I need to use?
  • 78
     After a lot of trial and error, I have found that the following solution works.  I'm not sure why.
    When you declare the grid in xaml, you need to set the GroupByArea style property.  I set it using the following syntax.
    {DynamicResource {x:Type igDP:GroupByArea}}
     If you don't put in the (x:Type) it will not work.
