The convert method is not called when using:
="Broker" >
Hello Sam,
Thank you for your post. I have been looking into it and the code you have provided and I suggest you use the following one instead of yours:
<igDP:Field Name="BROKER" Label="Broker"> <igDP:Field.Settings> <igDP:FieldSettings> <igDP:FieldSettings.CellValuePresenterStyle> <Style TargetType="{x:Type igDP:CellValuePresenter}"> <Setter Property="Background" Value="{Binding DataItem.BROKER,Converter={StaticResource BrokerColorConverter}}"/> </Style> </igDP:FieldSettings.CellValuePresenterStyle> </igDP:FieldSettings> </igDP:Field.Settings> </igDP:Field>
The difference is in the Binding’s Path, because the Binding’s DataContext is DataRecord. Please let me know if this helps you or you need further assistance on this matter.
