How to prohibit month changing when the LeftButton of mouse is down and then move mouse outside the calendar panel with single selectmode in XamMonthCalendar
There isn't such a problem with range select mode.
Thank you very much.
I have been looking into your question and I can suggest you handle the ‘ExecutingCommand’ event and implement the following functionality in its body :
private void xamMonthCalendar1_ExecutingCommand(object sender,Infragistics.Windows.Controls.Events.ExecutingCommandEventArgs e) { if (Mouse.LeftButton == MouseButtonState.Pressed && xamMonthCalendar1.SelectedDate.HasValue == true && Mouse.Captured == xamMonthCalendar1) { e.Cancel = true; } if (Mouse.LeftButton == MouseButtonState.Released ) { e.Cancel = false; } }
e.Cancel = true;
e.Cancel = false;
This way when you select a day and move the mouse out of the calendar panel, the month will not be changed.
If you need any further assistance on this matter, feel free to ask.
