Is it possible to create a mash like "dd/MM HH:mm", Ie. "29/04 13:30"? using XamDateTimeEditor 11.2.
I can create a 'dd/mm' mask for the day/month part, but I also need the time in 24 hour format.
Thanks for your help.
Ron.
I’m following up on your forum post. Please let me know if there is anything further that I can help you with regarding this question.
Glad you found the solution. This mask should return what you want, day, month, hour and minutes as digits with the hour related toa 24 hour clock.
Mask="{}{dd/mm hh:mm}"
This reference for Masks may also be helpful to you.
http://help.infragistics.com/NetAdvantage/WPF/2011.2/CLR4.0/?page=xamEditors_Masks.html
dd/mm hh:mm works.
The reuse of the 'mm' letters get interpreted correctly and 'hh' is in 24 hour time.
