We have an application where we add and remove different columns from the XamDataPresenter. Before they are removed, the customizations are saved and different customizations are loaded after the new columns are added. This causes an IndexOutOfRangeException. The reason for that apears to be a bug in which some of the associated filters are not removed when the columns are removed.
I've attached a repro. Just keep clicking the button until it crashes. It has crashed on me when Load Customizations has been called three or four times.
The repro was created with the 10.3 dlls, but I've seen the same thing happen in 11.2 and 12.1, so it should crash on those as well.
Is there a good workaround for this?
Thanks again.
Works great. Thanks for your help.
Works in the newest release.
Thank you.
I have logged this with development under ID: 111127 and I have also created a support ticket on your behalf: CAS-90959-WHKCTY and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://ko.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://ko.infragistics.com/Membership/MySupport.aspx
