240
'System.Windows.Documents.Run' error when clicking XamDataTree node.
I am using a XamDataTree. When I click on any node in the tree and then click on WPF MenuItem, I get following error.
Not sure what is causing this error, looks like it has something to do with  XamDataTree_MouseLeftButtonUp event.
I even tried to add the event handler for this event. Most of the times this event is not fired. Even when this event is fired I still get this error. It is a random behavior. Could you please help me out.
'System.Windows.Documents.Run' is not a Visual or Visual3D.
Stack Trace:    at System.Windows.Media.VisualTreeHelper.GetParent(DependencyObject reference)
   at Infragistics.Controls.Menus.XamDataTree.GetNodeFromSource(DependencyObject obj)
   at Infragistics.Controls.Menus.XamDataTree.XamDataTree_MouseLeftButtonUp(Object sender, MouseButtonEventArgs e)
   at System.Windows.Input.MouseButtonEventArgs.InvokeEventHandler(Delegate genericHandler, Object genericTarget)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
   at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.ContentElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
