I want to add reports to my project for the first time. I came across this guide:
http://help.infragistics.com/netadvantage/reporting/2011.2/clr4.0?page=creating%20a%20simple%20tabular%20report.html
In the "Add new item" window, I don't have the Infragistics category under the "Installed Templates".
I'm working with NetAdvantage 2011.2
My xamDataGrid, as well as all other Infragistic's controlers, works fine.
What can I do?
Hello Roy,
I have created a private support ticket on your behalf (CAS-91511-ZWVJGJ), where you can send me your key, so I can check what is your subscription and investigate your issue further for you.
I don't see the the "NetAdvantage Reporting 2011 Vol. 2 Complete Bundle", only the "NetAdvantage for Windows Forms 2011 Vol. 2 Complete Bundle" and the "NetAdvantage for WPF Line of Business 2011 Vol. 2 Complete Bundle".
When I install one of them, I get this MSG:
You can download just the installer for the Reporting by logging to our web site and going to My IG \My Keys and Downloads, select your key for 11.2 and then select the Product & Bundles TextBlock and click on the NetAdvantage Reporting 2011 Vol. 2 Complete Bundle.
Hope this helps you.
OK
The "Reporting" is really unchecked but now I'm facing a different problem:
My computer connected to the Internet via Sitrix and I don't have any way to connect it directly.
When I modify the installation, I need an Internet connection. Is there a solution for this?
I can suggest you run the installer, click “Modify” and make sure that the Reporting is clicked and highlighted like in the image below:
