995
Checkbox in grid
Hi
How do i set the below datagrid to have 1 text column and 1 checkbox column?
The grid is populated with the below vb.net 2010 code.
    Public Sub refreshBodylist()
        On Error GoTo ErrorHandler
        Dim con As SqlCeConnection = New SqlCeConnection(My.Settings.myCompactDBConnectionString)
        Dim sqlquery As String
        sqlquery = "SELECT Bodypart, checked_fg from dBodyPart order by bodypart"
        Dim cmd As New SqlCeCommand(sqlquery, con)
        daBodyPart = New SqlCeDataAdapter(cmd)
        Dim clienttable As New DataTable()
        clienttable.Locale = System.Globalization.CultureInfo.InvariantCulture
        Me.daBodyPart.Fill(clienttable)
        Me.bindingSource3.DataSource = clienttable
        XamGrid1.ItemsSource = bindingSource3
        Exit Sub
ErrorHandler:
        Dim errMessage As String = "Error Description: " & Err.Description & ".  Error Source: " & Err.Source & "."
        Dim errCaption As String = "Error"
        Dim errButtons As Integer = MessageBoxButton.OK
        MessageBox.Show(Me, errMessage, errCaption, errButtons)
        If con.State = ConnectionState.Open Then
            con.Close()
        End If
    End Sub
Xaml
 <ig:XamGrid HorizontalAlignment="Left" Margin="501,76,0,0" Name="XamGrid1" VerticalAlignment="Top" Height="188" Width="97" ColumnLayoutHeaderVisibility="Never">
<ig:XamGrid.RowSelectorSettings>
<ig:RowSelectorSettings Visibility="Hidden" EnableRowNumbering="False" />
</ig:XamGrid.RowSelectorSettings>
<ig:XamGrid.EditingSettings>
<ig:EditingSettings IsF2EditingEnabled="False" />
</ig:XamGrid.EditingSettings>
<ig:XamGrid.ColumnChooserSettings>
<ig:ColumnChooserSettings AllowColumnMoving="False" />
</ig:XamGrid.ColumnChooserSettings>
<ig:XamGrid.SelectionSettings>
<ig:SelectionSettings CellSelection="Single" RenderOptions.ClearTypeHint="Enabled" />
</ig:XamGrid.SelectionSettings>
</ig:XamGrid>
Parents
No Data
Reply
  • 7305
    If the column "checked_fg" is holding boolean type, the xamGrid should display the CheckBoxColumn as it matches the column types with corresponding field types. Try defining the CheckBoxColumn in XAML such as:  <ig:CheckBoxColumn Key="checked_fg" />
    For more information about column types see the Columns topic in XamGrid.
    Sam
Children
No Data
