I want to change the default DisplayName of XamCalculationManager aggregates.
For example
Maximum as Max, Minimum as Min
It should be reflected also in the Text displayed in SummaryDisplayArea. How can i achieve this ?
Kumaran Vellaisamy
Hello Kumaran,
Thanks again.
Hi Stefan,
I have done the same in another way. I have modified the style of SummaryResultPresenter. In that i have added a converter for Text property of TextBlock which displays the Result. It works fine.
Thank you for your post. I have been looking through it and I suggest you use the ResourceStrings of the XamDataGrid. You can add the following code after the InitializeComponent method is called:
Infragistics.Windows.DataPresenter.Resources.Customizer.SetCustomizedString("SummaryCalculator_Maximum_Name", "Max"); Infragistics.Windows.DataPresenter.Resources.Customizer.SetCustomizedString("SummaryCalculator_Minimum_Name", "Min");
Please let me know if this helps you or you need further assistance on this matter.
