1470
Error when setting DataTable.DefaultView as ItemsSource
I have a DataSet with 3 DataTables and two relations.
Like this:
Parent
Child
ChildValues
There is no problem, when i adding Parent.DefaultView as ItemsSource if all Tables are empty.
As soon i have one or more row in the DataSet and the grid property AddNewRowSettings.AllowAddNewRow is set to: Bottom, i getting this error:
Source:
InfragisticsWPF4.DataManager.v12.1
Message:
"DataManager hat versucht, eine Instanz des Typs 'System.Data.DataRowView' ohne leere Parameterliste zu erstellen."
Stacktrace:
   at Infragistics.DataManagerBase.GenerateNewObject()
   at Infragistics.Controls.Grids.RowsManager.GenerateNewObject(RowType rowType)
   at Infragistics.Controls.Grids.RowsManager.ResetAddNewRows(Boolean generateNewData)
   at Infragistics.Controls.Grids.XamGridRowsManager.ResetAddNewRows(Boolean generateNewData)
   at Infragistics.Controls.Grids.RowsManager.InitializeData()
   at Infragistics.Controls.Grids.RowsManager.SetupDataManager()
   at Infragistics.Controls.Grids.RowsManager.EnsureDataManager()
   at Infragistics.Controls.Grids.RowsManager.OnItemsSourceChanged(Boolean invalidateSelectionAndActivation)
   at Infragistics.Controls.Grids.RowsManager.set_ItemsSource(IEnumerable value)
   at Infragistics.Controls.Grids.XamGrid.ApplyItemSource(IEnumerable itemSource)
   at Infragistics.Controls.Grids.XamGrid.ItemsSourceChanged(DependencyObject obj, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
   at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
   at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
   at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
   at Infragistics.Controls.Grids.XamGrid.set_ItemsSource(IEnumerable value)
   at IBV.Modules.ExtendedSearch.ExtendedSearchControl.LoadControl() in C:\DevNet\ExternalAssemblies\ExtendedSearch\ExtendedSearchControl.xaml.cs:line 104
Inner Exception Source:
mscorlib
Inner Exception Message:
Constructor on type 'System.Data.DataRowView' not found.
When the DataSet is empty or the grid does not allow AddNewRow there is no excpetion thrown.
Whats wrong here?
