hi team,
can u give me the sample code for binding pie chart in runtime
dp.Label = dsSearchCriteria.Tables[2].Rows[i][0].ToString();
dp.Value =
.ToDouble(dsSearchCriteria.Tables[2].Rows[i][dsSearchCriteria.Tables[2].Columns.Count - 1]);
series.DataPoints.Add(dp);
series.Fill = RGB;
xamChart.Series.Add(series);
currently i am doing like above but its come for only one series
regards
Raj
Hi Raj,
Let me know if you have any further questions.
The code you are using is correct for adding data points to a pie chart series at run time. I've included a sample using this method to create a pie chart series at runtime through the push of a button. Is this what you are looking for?
