20
Floating window - closing tabs
When I drag a TabGroupPane outside the main window it becomes a floating window. If I press the Close button on the Floating window it closes the whole window, not an active tab. Is this possible to change this behaviour? I discovered there is an event 'PaneClosing' in XamDockManager but in Silverlight edition, not WPF. So how can I intercept this event in WPF or change the described behaviour in any way?
  • 200
    Verified Answer
    The solution is to handle XamDockManager WindowClosing event. However in order to subscribe to this event, you need to subscribe to XamDockManager ToolWindowLoaded event which is fired whenever ContentPane or TabGroupPane is dragged out as floating window. Within ToolWindowLoaded you should subscribe to WindowClosing event:
    void xamDockManager1_ToolWindowLoaded(object sender, PaneToolWindowEventArgs e)
       e.Window.Closing +=
    new System.ComponentModel.CancelEventHandler(xamDockManager1_WindowClosing);
